3m sanding disc
Old Nov 16, 2006 | 10:43 PM
flying tomato's Avatar
flying tomato
3m sanding disc
decided to take the bronco all the way to bare metal. bought a 7" maketa and some 8" green 3m sanding discs. There is some overlapping of the disc and the new rubber pad for the grinder. Fired everthing up and the disc just works free from the rubber pad. Do I need to scuff up the rubber? Buy 7" pads? Put some tacky substance on the pad? any advice is appreaceted.
Old Nov 17, 2006 | 03:18 AM
fordpick-up's Avatar
fordpick-up
The 7" maketa is a electric sander or what?
Old Nov 17, 2006 | 08:35 AM
flying tomato
sorry, the 7" maketa is electric
Old Nov 18, 2006 | 02:03 AM
fordpick-up
If the pads you are trying to use are self adhesive and the backing pad on the sander has a locking nut this is your problem. The self adhesived pads are designed to fit a backing pad like on a DA sander. Anyway I would recommend going with a DA air sander. But if you want to use your new sander you can try the wire cup brush. Good Luck
