help if u can
Old Nov 16, 2006 | 08:50 PM
theman79's Avatar
theman79
help if u can
538-insufficient RPM change during KOER dynamic response test. can anyone explain this for me. need help.
Old Nov 17, 2006 | 10:58 AM
EPNCSU2006's Avatar
EPNCSU2006
After the engine code (3 for I6 and 4 for V8 gas) there will be a single flash on the check engine light (not sure how it works on a scanner) which is your signal to stomp the throttle momentarily, turn the steering wheel a little bit, and touch the brake pedal. I think this code is just from not doing this during the test...give it a try again and see if that fixes the code.
