engine stands?
Old Nov 16, 2006 | 04:59 PM
notlowyet's Avatar
notlowyet
engine stands?
Does anyone know what size bolts to use on an engine stand for a 5.0L engine?
I just got my stand and don't know what size and length bolt to use. Thanks again for the help.
Old Nov 16, 2006 | 05:22 PM
DetailerDave's Avatar
DetailerDave
I believe the bolts are 7/16-14, but for the length you would need to measure the thickness of the part where the bolt goes thru your engine stand, then add about 3/4" to that. Now- your bolts could be metric. If they are then they are probably 12-1.5.
Old Nov 16, 2006 | 07:08 PM
notlowyet's Avatar
notlowyet
the mounting studs on the stand are 2.25" long.
also, what holes are used on the motor, is it the transmission mounting holes?
Old Nov 16, 2006 | 08:04 PM
DetailerDave
Yes- the stand would bolt to the block where the trans would be.
Old Nov 17, 2006 | 01:53 AM
Huntfamily53's Avatar
Huntfamily53
Take a tranny mounting bolt (assuming you have one) to the Hardware store to match threads (coarse I believe). Get Grade 8's that match. For the length of the bolt, measure the stand where the bolt goes through (2.25"?) as well as the width of engine where the tranny bolts go.(1-2 inches?) I did mine like that. I got ones just a hair longer and bought a stack of thick washers (two per bolt) to keep the bolt from being too long. I'll measure mine tomorrow to be sure too late now.
Old Nov 17, 2006 | 02:21 PM
notlowyet's Avatar
notlowyet
Everything is on and all is good. I just got my 5.0 dropped off and the guys helped me toss it on the stand. So now I'm just looking to switch everythign to a carb instead.
