C6 wont shift?
Old Nov 16, 2006 | 03:02 PM
wvbogger's Avatar
wvbogger
C6 wont shift?
I have a 77 f-150 with a c-6 behind a 400. The problem is the transmission will not shift once the kickdown is activated at full throttle. It will hold 1st gear until she redlines or blew if held long enough. It will shift only after the throttle is let back up. All other shifting is fine. Since the downshift linkage is a solid connection, what inside the transmission allows it to shift with this linkage activated? Would it be the modulator? Any suggestions? Thanks
Old Nov 16, 2006 | 09:02 PM
Torque1st's Avatar
Torque1st
Posting Legend
Sounds like some valves sticking in the system. Try a good tranny fluid flush.
