OD Light "OFF" flashing
Old Nov 16, 2006 | 08:15 AM
MattsExcursion's Avatar
MattsExcursion
Hi everyone, I was wondering if anyone knew what some of the causes for the OD light on the gear shifter to be flashing off when you start driving it. It doesn't shift weird or anything, but I don't know what the flashing light means. The truck is a 2000 Excursion 4x4 with 7.3L Diesel.
Old Nov 16, 2006 | 09:19 AM
rlh68050's Avatar
rlh68050
Error code being set in the trans module. Kinda same as the check engine light, but for the trans. You will need to go to a shop that has a scan tool that will interface with the trans module. Generic OBD scanners will not do it.
