Cruise control surging
Old Nov 16, 2006 | 06:47 AM
ChurchBuilder's Avatar
ChurchBuilder
1989 F150 5.8L, 351W: Yesterday, on the way home from work, my cruise control started surging. When I set the cruise it surges and the gas peddle goes up and down with each surge. It did it again this morning. It's been raining a lot but that's the only difference there's been lately.
Old Nov 16, 2006 | 03:09 PM
cpettymore7777's Avatar
cpettymore7777
i think i read once on a problem like this and it was a vss.
Old Nov 16, 2006 | 03:16 PM
nighthawk285's Avatar
nighthawk285
i have the same problem, only it happened after I raced my friend and broke the spring inside the speedometer, but since our speedometers are mechanical, I didnt see the connection. does the VSS in the rear diff control the cruise on our years? (87-90)
Old Nov 16, 2006 | 03:33 PM
compaddict's Avatar
compaddict
Mine got better after fixing a vacuum leak. YMMV.
Vince
Old Nov 16, 2006 | 07:46 PM
nighthawk285
yeah, thats what I thought mine was, but there were no leaks, and it only surges when the speedometer does the same (because of the broken spring), but its mechanical and gets its signal from the cable in the transfer case, and the cruise gets its signal from the VSS correct?
