Everytime it rains
Old Nov 15, 2006 | 08:50 PM
lgaltuna's Avatar
lgaltuna
Question Everytime it rains
I have a problem every time it rains. I have a 99 Ranger 3.0 and I get squealing. I installed a new serpentine belt about 6 months ago so I don't think it is the belt. I can't tell where the squealing is coming from. I think it is either the idler pulley or the tensioner. It squeals after rain but after a few days of dry weather the squealing stops. The tensioner arrow is within the correct range. I would appreciate any thoughts or suggestions. Thank you
Old Nov 15, 2006 | 08:59 PM
matt's2.9STX's Avatar
matt's2.9STX
Get a simple mechanics stethoscope & listen to the bearings of each accessory as it runs. These can be had for around $5-10 at tool supply or parts stores. Could try and see if drive belt anti-squeal spray helps. Good stuff regardless of problems or not. O sometimes may need to clean the pulleys really well with simple green and brush. Even a brass wire brush in a bad case.
Old Nov 16, 2006 | 08:15 AM
Rags's Avatar
Rags
Could be your tensioner is just bad! even though the the arrow is in the correct range the spring could be weak and not allowing enough tension on the belt.
