Sponsored by: Kumho
how to modify pump
Old Nov 15, 2006 | 07:07 PM
oldblue31's Avatar
oldblue31
how to modify pump
Does anybody know how to modify the steering pump on a 95 f350 so that I can pump more fluid.I have to rev the engine to steer sitting still or while turning moving slowly.
Old Nov 16, 2006 | 03:18 PM
pud's Avatar
pud
you need a new pump. Mine turns fine at idle and its got a 1200lb diesel over the front axle.
Old Nov 16, 2006 | 09:50 PM
oldblue31's Avatar
oldblue31
Yeah, i've just heard that you can drill em out somehow to flow more.
Old Nov 16, 2006 | 10:35 PM
Torque1st's Avatar
Torque1st
Posting Legend
No drilling, you need a new pump.
Old Nov 17, 2006 | 01:26 AM
pud's Avatar
pud
you might be able to drill an orifice larger or not, I dont know. If it cant turn the wheels on idle, that wont help much. A used pump is easy to find and you would have to pull the junk one out anyways. Might as well put one that works in...and if you can find a tech write up on drilling it then practice on your junk one.
Old Nov 17, 2006 | 02:49 AM
Torque1st's Avatar
Torque1st
Posting Legend
There is no drilling on a pump, no orifice, no nothing like that... Been working and teaching hydraulics for years. Trust me on this.
A used pump may even be better than a reman pump. Most of the reman pumps are noisy junk. The rebuilders have no idea how to rebuild a pump. A NEW pump from Ford is another po$$ibility.
Whenever you work on the PS system you need to install a filter in the return line or you can kiss your replacement pump goodbye.
Wix Transmission/PS Filter
Wix transmission/PS filter #58964
Ford equivalent filter kit #XC3Z-7B155-AA
Ford filter alone #XC3P-7B155-BA
200 psi working, pressure relieved, magnetic
change yearly or 12000 miles
Old Nov 17, 2006 | 11:23 AM
oldblue31's Avatar
oldblue31
Thanks for the info.I'll price a new one and also look into some of the remans.
