TQ lock up mod
Old Nov 15, 2006 | 06:27 PM
99 7.3 towrig's Avatar
99 7.3 towrig
TQ lock up mod
Sorry, but the search is not working. this comming week im planning on doing the EBPV brake an TQ lock up mod. Im planning on using an on/off switch with 4 pins, an having one side make the ground connection for the TQ an the other side send the reduced 12v to the EBPV solinoid. what im looking for is the wire/s that i need to find an ground for the TQ and where they are located. this is a late 99'. thanks
-Kurt
Old Nov 15, 2006 | 09:25 PM
Don Tim's Avatar
Don Tim
According to the data recieved on the forums, On the drivers side fenderwell under the brake Master cylinder you will find 3 to 4 connectors. 3 black and one gray. You want the gray one pin number 6 violet with yellow tracer, The side leading to the transmission. Good Luck make sure you do it in the light and get the RIGHT wire,
Tim in TEXAS
Old Nov 16, 2006 | 03:27 AM
ron's power stroke's Avatar
ron's power stroke
https://www.ford-trucks.com/forums/2...brake-mod.html
this is the exhaust brake..cant seem to find the t/c lock yet sorry
edit:: i found it good luck http://guzzle.rbmicro.com/tclock.html
Old Nov 16, 2006 | 08:48 PM
Don Tim's Avatar
Don Tim
Wiring question? can you use a lighted switch on this mod? If so how is it configured? I found the purple/yellow tc wire and can make it engage but the switch is throwing me. Guzzles diagram doesnt provide the switch schematic maybe I just blind
Old Nov 16, 2006 | 09:41 PM
guzzle92's Avatar
guzzle92
I actually used an LED switch on my project but it will only light when you throw the TC lockup switch to ON.
If you want to be able to see when the PCM locks up the TC, you will still need an external LED indicator.
Most lighted switches have 3 electrical connections on them (SPST)
One marked battery (+) which would connect to the +12v part of the circuit, in my schematic it would be wherever you are picking up the 12v switched voltage.
One marked accessory (+) which on my schematic would be the relay.
The last terminal marked Ground (-) which would connect to chassis ground.
Whenever the switch is flipped, both the relay and the internal LED in the switch are turned on. When the switch is turned off, both the LED and relay are taken out of the circuit.
Old Nov 16, 2006 | 10:35 PM
Don Tim's Avatar
Don Tim
So the relay must be used to activate the lighted switch? Otherwise non lighted? I was also able to use the aux led when the TCC is activated but no switch light.
mtnsammy
Feb 26, 2014 11:17 AM
SuperDutyScaler
Computer Chips & Tuners
Jan 24, 2012 01:03 PM
I6power
General Automotive Discussion
13
Mar 25, 2010 10:23 PM
jpeters1
Modular V10 (6.8l)
Jul 14, 2009 10:12 AM
frdhighboy77
May 19, 2004 11:41 PM
