Electrical - Fog Lights
Old Nov 15, 2006 | 03:34 PM
VaSheriff's Avatar
VaSheriff
I bought these replacement fog light bulbs on eBaY.....
<TABLE width=529 align=center border=0><TBODY><TR><TD vAlign=top width=199 height=111>
Bulb Type: H10
Wattage (draw): 55
Wattage (output): 80
Color: Arctic White
Color Temp: 7000K
Warranty: 60 Days
</TD><TD vAlign=top width=320>
High output Halogen Headlight Upgrade
European White Light, similar to High-Intensity Discharge (HID) Lighting, for optimum visibility.
Quick & easy install, no modification necessary.
No wiring upgrade necessary
</TD></TR></TBODY></TABLE>
It clearly says -> No wiring upgrade necessary.
But on the Nokya package, it says:
Warning: Wiring harness highly recommended!
So............................ which is correct?
Old Nov 15, 2006 | 11:23 PM
quietman's Avatar
quietman
Sylvania silverstar 9005's are correct.
pop right in...
They ROCK as far as being insanely bright, and after two years and 35K miles being on all the time (I use them as daytime safety lights) in hot hot and cold conditions have been completely reliable with no wiring upgrades...
...of course also check out the thread on fixing the light circuit so they stay on with high beams, that is tres cool...
_____________________
Quietman
www.roenation.com
2005 EXCURSION LIMITED-options (everything) equipped Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein $$ mono-gas shocks, Rancho Steering Stabilizer
Silverstar 9005 fog and H13ST headlights + wiring mod to run high beam and fogs together,
BFG 315/75/16 AT KO's on Factory Mags, 22" front and 18" rear rain-x wipers,
LANDYOT Generation II Radius Rods, Ford factory hood insulator
Old Nov 16, 2006 | 12:37 AM
ramsmoker's Avatar
ramsmoker
Talking fog lites
The catalog I looked called for H10 bulbs. I to shop e-bay and mine just cautioned ov a wire overload. Mine have been for three years with no problem. I boughy head lights from the same guy who shipped direct from Hong kong. If your worried, turn them on and check the harness for heat. You can always install a relay but i don't think you'll have a problem.
Old Nov 16, 2006 | 02:03 PM
madhatch's Avatar
madhatch
get the upgrade.
if you dont in a couple of weeks/ months it will burn your wires. The kit I got from a local dealer was from street glow and was like 30 bucks. I boutch one for each car. it has 2 relays (1 right, one left) and plugged directly into the factory light socket and looped to the battery. 15 minute install minus having to re wire a factory plug into the burnt one.
well worth the money.
