Testing mudulation in brake controller
Old Nov 16, 2006 | 05:40 PM
JOE-M's Avatar
JOE-M
You must have the wrong pin. If this is true, when you plug the connector to the trailer the magnets would be fully energized and the wheels would lock. If you start moving the manual slide the controller will start off at lower voltage and increase voltage the further you slide it. Maybe you have a short in the plug, but I'm guessing your setup used to work?????
Joe
Old Nov 16, 2006 | 06:49 PM
Steina's Avatar
Steina
CO River Rat
Here's a link to industry wiring standards: http://www.accessconnect.com/trailer_wiring_diagram.htm
Steve
Old Nov 16, 2006 | 07:40 PM
jorlee's Avatar
jorlee
Q.) What are the functions of the four wires?
· Black is the Battery Power
· White is the Ground
· Red is the Signal from the Brake Light Switch
· Blue is the Electrical Brake Feed
http://www.tekonsha.com/faq_wiring.html#001
http://www.tekonsha.com/faq.html
Depending On which controller he has 12 volts at the blue wire is normal on the voyager, but others a different voltage is normal, when no trailer is connected. If there is 12 volts at the blue wire when the trailer is connected then there is a different problem.
If all else fails they have tech support with a 800 number. Tech Support at 888-785-5832
genscripter
S. California Chapter
Feb 21, 2013 04:38 PM
padlikehel
Mar 19, 2010 07:57 AM
tchile
Bronco II
Feb 26, 2010 10:03 PM
FORD !D! TURBO
Dec 9, 2009 11:19 AM
karmaz_payvment
Electrical Systems/Wiring
May 9, 2004 06:07 PM
