93 ranger 5 speed interchange
Old Nov 15, 2006 | 12:22 PM
josh123's Avatar
josh123
I have a 93 Ranger with a 5 speed but 5th gear is out. What other years/models have this same transmission? It is a 4x4 with a 4.0. Also, will the transfer case interchange. I would like to change them as one unit. Thanks
Old Nov 15, 2006 | 01:13 PM
BSmitty's Avatar
BSmitty
Any 4.0l OHV equipped 4x4 will work, and a 2.9l from '88-'92 4x4 that was equipped with a mazda transmission will work as well, just beware the Mitsubishi FM146 also used from '88-'92 on 2.9l's.
Old Nov 15, 2006 | 07:18 PM
RnMEtt7500's Avatar
RnMEtt7500
if your just looking to fix it, Not long ago I had the same problem no 5th. I bought a fifth/reverse update kit (dose not come with the fifth gear itself) and a new fifth gear and not counting the time to pull trans out of my truck and put it back afterwards only took about 1/2 hour to fix. I bought it from Rockland Gear for about $250 if I remember correctly.
