Sponsored by: Real Truck
ABS Module
Old Nov 15, 2006 | 12:00 PM
dynarider1995's Avatar
dynarider1995
ABS Module
Does anyone know where the ABS module is on a 2004 6.0L
Sorry I can’t do a search for this. I am going to install the Superlift Speed Sensor Calibrator.
I’m just trying to do my homework before I start this MOD
Old Nov 15, 2006 | 01:29 PM
EnviroCon's Avatar
EnviroCon
It's right below the driver's side battery. The easiest way to get to it is to remove a bolt (it's a very small bolt) and clip, near the bumper bracket, that hold the wheel well liner in place, and the first small bolt that holds the liner to the 1/4 panel, then gently pull back the wheel well liner. You'll then be able to look-up and see the ABS module and the plug that has the wires you need for the TruSpeed. Once you remove the plug from the module, there's enough slack in the wire loom to pull the plug down into the wheel well to be able to solder and heat shrink the wires.
Old Nov 15, 2006 | 01:46 PM
dynarider1995
Thanks EnviroCon
Thanks that was just what I was looking for. This is the best site for ford trucks I have ever seen. Thanks again
