Headers and starter clearance!!!!!
Old Jul 15, 2002 | 07:55 PM
Franklin2's Avatar
Franklin2
Old Jul 15, 2002 | 09:42 PM
55FordLover's Avatar
55FordLover
I have the flowtech dropside headers for my 302. The p/s header is rubbing against the back of the starter where the wiring is. The question I have is, does ford have another starter that can fit a 302 with the wires on the side of the housing and no longer than about 6-8 inches long???? ANYBODY WITH SUGGESTIONS, PLEASE give up your knowledge.
James
54 Ford F100 (302/AOD)
Old Jul 16, 2002 | 06:22 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Motorsport M-11000-A50 is a smaller permanent magnet starter that might fit. They were used on Fords starting around 90 or 91. What year starter do you have? Is it the large frame older starter?
Old Jul 16, 2002 | 06:47 AM
55FordLover
I have a 1977 Lincoln Versailles 302. So the rebuilt model from checkers is what I have man. Any more suggestions or ideas?????
James
Old Jul 9, 2006 | 06:50 PM
cgeibel's Avatar
cgeibel
Same issue on a 52
I just put flow tech block huggers in my 52 which has a '79 302 motor. I went to the headers becase I had an interfence with the standard manifolds and the steering box on the drivers side. The new headers fixed that problem but I now have interfence on the starter on the left side with the headers. The interference is not much. Its just as you ddescribe above. If the headers could be bent a little out towards the frame then I would be ok. Is this possible and if so how?
Old Jul 10, 2006 | 07:03 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
This is an old thread …however stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
