Brake Proportioning Valve
Old Jan 24, 2007 | 06:11 PM
Hamberger's Avatar
Hamberger
Originally Posted by Ben-jamin
glad you have the problem in hand and i like that you opted for the better shoes and pads. i've had alot of rear brake issues with these fords, even 1/2 tons. found that alot had to do with NOT turning the rear drums or at least checking them to make sure they are not out of round, then scuff 'em up real good to help take the glaze off so they will brake-in better and last longer.
i read a break-in procedure from Bendix - 30 stops from 30mph with 30 sec. cooldown interval-works great.
something else i've run into is putting duelly wheel cylinders on a single wheel truck really increases apply pressure and increased lock-up
also contamination makes them want to lock especially when cold.
Benjamin,
You covered a lot of good points above, unfortunately my complaints about the rear brakes on my 93' go back to the very day I bought the truck. The diesel used the HD 3" shoes and larger cylinders I think that with all the braking power on the rear things are fine if the truck is loaded, but running around empty is darn right dangerous in my mind, and the RABS system did nothing to improve that, it actually made it worse on wet and bumpy roads.
Seb....
Old Jan 25, 2007 | 10:55 AM
Hamberger's Avatar
Hamberger
Here is a picture of Proportioning Valve installation:
https://www.ford-trucks.com/user_gal...id=140104&.jpg
Old Jan 25, 2007 | 11:52 AM
F450 Aaron's Avatar
F450 Aaron
What year did they start putting the RABS in? I have the box described in my rig just above and to the right of the gas pedal and also have the mechanical valve. I s this right or is the box I am seeing something else? Are there any dash light for the RABS?
Thanks,
Old Jan 25, 2007 | 12:02 PM
Hamberger's Avatar
Hamberger
Thanks,
I think the first RABS came out in about 87' and the box was located were you described it till 91'.
In 92' they started putting the control box behind the glove compartment.
As I said many times, the early RABS systems will actually increase your braking distance under conditions such as wet roads, bumpy roads, gravel, etc... Also I felt that the proportioning between the front and the rear was not right with too much emphasize on the rear brakes.
Seb....
s.squared-39
Dec 5, 2016 04:46 PM
Boundertom
Sep 11, 2016 07:47 PM
high6
Sep 6, 2016 01:23 AM
phoneman91
Apr 21, 2005 01:49 AM
robroyg
17
Sep 9, 2003 06:05 AM
