Door ajar
Old Nov 15, 2006 | 08:52 AM
goatsniffer's Avatar
goatsniffer
Unhappy Door ajar
I have an '03 F-250 SD 4X4 Super Cab. I bought it last week used . i have noticed that the driver side door(s) have been intermitently seeming not be regognized by the truck that they are closed. The door ajar indicator will stay on for a while as well as the dome and bed lights. Last night they stopped going off totally. For now i have all the bulbs out. Help.
Old Nov 15, 2006 | 09:10 AM
01lariat's Avatar
01lariat
I think if you spray the door latches good with wd-40 it will cure the problem. That happened to mine an 01 Shortly after I bought it a couple years ago. Somebody told me about this fix and it worked, no problem since. Good Luck. I wish the problem im having now was that simple.
Mike
Old Nov 15, 2006 | 10:16 AM
spunks00's Avatar
spunks00
i work at a car lot and the door switches are in the latch...so from my understanding if the wd-40 dont work you will have to order a new latch. (that was on a 03 f150 supercrew)
Old Nov 15, 2006 | 10:19 AM
Dogwood36322's Avatar
Dogwood36322
WD40 followed by a good silicone spry lube will do the trick. Had the same problem on my 01 Excursion. Cured the problem.
Old Nov 15, 2006 | 11:38 AM
Yukon's Avatar
Yukon
Ive had this with both my 1/2 ton and now my 3/4 ton. Lube it up good, activate the mechanism several times and you should be all set. spunks00 is right, the switch is in the latch so don't worry about the hinge area.
Old Nov 16, 2006 | 11:10 AM
wfmcbride's Avatar
wfmcbride
Same problem with my 99, WD-40 did the trick.
Old Nov 16, 2006 | 11:12 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I will follow the others and also say that my '99 did the same thing and the WD-40 worked.
