302 vs 351w
Old Nov 14, 2006 | 11:58 PM
crayonbreaker's Avatar
crayonbreaker
302 vs 351w
well all know that there is no replacement for displacement but what do you guys think you could get more
power
out of for less the 302 or 351w the only hitch is i would like to use stock rods, crank, and heads
Old Nov 15, 2006 | 04:57 AM
HemiEater's Avatar
HemiEater
I would port the heads and run the 351....
Old Nov 15, 2006 | 11:54 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. Check the links at the bottom, and the menu bar at the top, of the page for more information and resources. Have fun!
Old Nov 15, 2006 | 01:07 PM
P51D Mustang's Avatar
P51D Mustang
Me too, unless he's already got a 302. The 351w is basically a scaled up, raised block 302. Same basic design, same heads, same rod ratio...ect.. All things being equal, they will produce about the same HP per cubic inch. The tourqe output coming off idle, will be greater with more cubes too. Porting the heads is highly reccomended, because the stock heads are a bit restrictive, even on a 302. They will be even more restrictive on a larger displacement version of the same basic engine.
