Sponsored by: Real Truck
brake light gremlin? '04 PSD
Old Nov 14, 2006 | 11:41 PM
kevin1465's Avatar
kevin1465
Anyone know why my brake lights might come on with the truck parked and not running? Just the brake lights, and nothing else. I have a trailer brake controller installed...maybe this is the cause? Oh...no pets or kids inside, either...
Old Nov 14, 2006 | 11:48 PM
Cowboy Brett's Avatar
Cowboy Brett
The first place I'd look would be the stoplight switch. That's right there under the dash on the lever part of the brake pedal. The thing to watch there is that you keep the orientation of the pins and washers if you take it out.
The only other thing you might look into would be the brake controller harness if you wired that up yourself. You'll want to make sure there is no short between the brake control power supply and your brake switch signal wire.
Old Nov 15, 2006 | 05:47 AM
rwilimo's Avatar
rwilimo
I know I remember reading some post's of people having this caused by a faulty brake controller before. I think there may have been a certain brand/model that caused this. I would try a search.
Old Nov 15, 2006 | 06:50 AM
350z's Avatar
350z
Arrow
My 04 did the same thing ,the brake lights would come on out of the blue , sometimes a few seconds or minutes , I bought a new brake switch , not the problem , then I started to put a chair in the driveway waiting for it to happen , when it did I noticed that the brake controller was lit up , bingo ! I called the company that made it (Valley ) and the person told me that they had some software issues that caused that exact problem to happen , they asked me for my model number /address and sent me a new one in advance , and picked up the old one , can't beat there service anyway , problem solved !, Craig.
Old Nov 15, 2006 | 11:43 AM
kevin1465's Avatar
kevin1465
Would you believe that my controller is a Valley model? I'm going to contact Valley right now, and see if I can't get this gremlin out of my 250. Thanks to all who responded--you're a tremendous resource!
Old Nov 15, 2006 | 12:05 PM
kevin1465's Avatar
kevin1465
A little more info: I just spoke with Jerry at Valley Industries. The problem with my brake controller (model 52740) is contamination, which causes an intermittent short, activating my brake lights. He says the switch is self cleaning, so activating the switch 15-20 times cleans the contacts. He suggested I try this, and offered to replace the unit if this doesn't work. Nice to find a company that stands behind their products....
Old Nov 16, 2006 | 01:10 PM
350z's Avatar
350z
Arrow
I had the same model also , and was told the same thing , it didn't fix mine , got the replacement and everythings great ! , Craig.
