Sponsored by: Real Truck
gearing question!!
Old Nov 14, 2006 | 09:44 PM
Spectre 023's Avatar
Spectre 023
gearing question!!
ok...i need a little help....
can anyone list ALL the parts ill need to swap my rear gears from 3.73's to 4.10's.
from all ive read, 4.10 is whats for me, but i still need a little help on what i need to complete this "little" project.
i am going to have my local shop do the actual swap for me, but i need a list of everything that ill need.
i would greatly appreciate any help and imput.
thanks!
Old Nov 14, 2006 | 10:20 PM
TwelveAlpha's Avatar
TwelveAlpha
You dont need a list, just a website. Try ring-pinion . com. Tell them what your axles are (i.e. I have a dana 60 and a sterling 10.5 - or whatever you do have. Get the ring and pinion and the complete overhaul kit. Done. Gear oil you can get local easy enough.
Old Nov 14, 2006 | 10:30 PM
Spectre 023
thanks alot man, ill look into it
Old Nov 14, 2006 | 10:32 PM
Spectre 023
also...how can i figure out whether i have the dana 50 or dana 60, and do i need 10.5 gears for the rear sterling or 10.25..ive seen both and am a bit confused....
Old Nov 15, 2006 | 08:02 AM
birdman127's Avatar
birdman127
Just call them at Randys...They will answer your questions. Gears, master overhaul kits for both axle's AND ask for the rear hub seals....They dont come with the rear kit but should be replaced while it is all apart.
Your front axle is a Dana 50 rear axle is 10.5 Visteon/Sterling
Old Nov 15, 2006 | 10:48 AM
Autobahn F-250 Lariat's Avatar
Smile
From what i have read on here most guys with 5.4l find they get more bang for the buck by going to 4:56 just my .02
try a search to see for yourself
Old Nov 15, 2006 | 04:53 PM
PHWLEE's Avatar
PHWLEE
thanks!
Give Randy's Ring & Pinion a call. They will give you everything you need. When I got mine, I got the Yukon gear sets, I also got the master overhaul kits - one for the front and one for the rear.
Old Nov 15, 2006 | 05:17 PM
Spectre 023
can anyone give me an estimate on total cost?
Old Nov 15, 2006 | 05:23 PM
PHWLEE's Avatar
PHWLEE
Exactly $945.11 (from Randy's Ring and Pinion) for all of the gears and kits including shipping, and about $600 for installation from a local differential specialist.
So, about $1600 give or take to be exact.
Take a look at this thread, I wrote down the exact numbers:
https://www.ford-trucks.com/forums/5...uestion-2.html
Old Nov 16, 2006 | 02:07 AM
Spectre 023,
since your close to mcallen why not have trucktoyz hook you up with gears those guys are top shelf from what i hear....they quoted me $1500 for 4:56 complete install
Old Nov 16, 2006 | 04:47 PM
Spectre 023
haha....i was going to head over there tommorow as a matter of fact.
where are you from, near here?
Old Nov 17, 2006 | 12:47 PM
stevenn1's Avatar
stevenn1
Originally Posted by Autobahn F-250 Lariat
From what i have read on here most guys with 5.4l find they get more bang for the buck by going to 4:56...
I AGREE! After going the distance - spending lots of time and money to only switch from 3.73 to 4.10, you will be very dissapointed.
Old Nov 17, 2006 | 12:54 PM
Talking
I live near Rockport i'll be heading home soon
Old Nov 18, 2006 | 04:32 AM
Byron2's Avatar
Byron2
i just had the swap in my van done e-350
3 days ago this back yard shop the total cost for the gear swap was 500
i gave the guy a extra 50 he is looking for a posi carrier that he will rebuild and put in
for a other 150 he is 22 miles ne of pittsburgh
