Sponsored by: Real Truck
Help installing Superlift Truspeed
Old Nov 14, 2006 | 05:46 PM
Trey's Avatar
Trey
I am trying to install a Superlift Truspeed in my '07 F20 with a V-10. I was wondering if someone could clarify where in the heck the ABS wire that you cut is located. I have installed a second battery over next to the airbox and don't want to remove the battery tray (it was a pain to install) if it's not under there. Any help would be sincerely appreciated. Thanks!
Old Nov 14, 2006 | 07:13 PM
Nookbom's Avatar
Nookbom
speed sense wire
The speed sense wire is the wire that you need!!! It is located at the cluster or at the radio plug, it is a grey/black wire (the only grey/black on the radio plug). You should be able to cut it there and follow the instructions after that.
Hope this helps!!
Old Nov 14, 2006 | 09:35 PM
Trey's Avatar
Trey
Hope this helps!!
The instructions say that the wire is attached to the ABS unit. It seems that the wire to the radio harness terminates there and therefore is already downstream of the trucks computer. I'm just trying to figure out where the harness under the hood is on the newer model V-10 so I don't have to remove 2 hours worth of aftermarket stuff already crammed in there. I should have done this before installing everything else. D'oh!
A picture would be priceless.
Old Nov 14, 2006 | 09:36 PM
jim6liter's Avatar
jim6liter
Hey Trey just wondering where you got your truspeed from?Thnx
Old Nov 14, 2006 | 10:22 PM
Trey's Avatar
Trey
I bought mine from 4 Wheel Parts here in San Antonio. But if you want to save a few bucks order it online and avoid the sales tax. They are around $180-$200. The really slick thing about them is that they have a switch that lets you save two seperate settings. I will use my GPS to calibrate the first position for highway air pressure. For my second setting I will figure my minimum safe air pressure for running in deep sand and use the cruise control and GPS to calibrate it for aired down tires. With this dinky 29 gallon fuel tank, monitoring your fuel consumption accurately is imperative when running the 63 miles of beach that is Padre Island National Seashore.
...............so about those wires?
Old Nov 14, 2006 | 10:29 PM
Spectre 023's Avatar
Spectre 023
padre island ftw!!
i drive out there all the time, good luck with installation bro
ybnormal70
Jul 22, 2017 11:12 AM
lowmpgv10
Jul 28, 2016 11:21 AM
ctimrun
Feb 13, 2012 06:35 PM
Da Mother Ship
Apr 4, 2005 11:18 AM
