new shocks
Old Nov 16, 2006 | 09:08 AM
dukman22's Avatar
dukman22
Jrabenaldt, How much difference did you notice with just the sway bar, before you put on the shocks. The reason I ask is that I have just installed a set of Pro Comp ES9000 shocks a couple of days ago. I chose them because I was not sure if I was going to keep the vehicle for very long. They replaced some Monroe Sensatrac's which came on it. I have not seen that dramatic a difference with the new shocks and there is still more body roll than I would like. My thought is to add the Hellwig and see if I can live with it for a while instead of pluncking down $250 for the Bilsteins and just throwing away the Pro Comps.
Old Nov 16, 2006 | 09:13 AM
MOOK929RR's Avatar
MOOK929RR
a little trick for that front shock that makes it a piece of cake...but you need 2 jacks. Obviously one to raise the truck and let the suspension hang, and remove the old shock. Once you insert the top part of the new shock, and secure the bottom part, take a second jack and use it to compress the suspension, which will compress the new shock and compress that thick bushing a bit. Then putting on the second piece of the bushing and getting that top nut started is a piece of cake.
Old Nov 16, 2006 | 10:48 AM
jrabenaldt's Avatar
jrabenaldt
Add the Helwig before you eat the cost of the shocks. The difference it made in controlling the lean while I had the OEM shocks still installed was dramatic (but I was looking critically for any change). I wouldn't toss the ProComps yet.
I second the use of jack stands and a floor jack. The combination was perfect for doing the backs by compressing the shock then sliding it into place as it expanded.
Old Nov 16, 2006 | 11:52 AM
dukman22's Avatar
dukman22
Thanks for the response. You know how people are. I had just about deceided to go with the sway bar, but I wanted you to sell me on it. Ha Ha.
I really hated to just pull the Pro Comp's off to put on the Bilstein's, but I have pitched more money than that away trying to chase a penny. Thanks for your input.
Old Nov 16, 2006 | 02:31 PM
jrabenaldt's Avatar
jrabenaldt
It still won't corner quite like a mustang but it wont be a 15 year old escort anymore either.
Old Nov 16, 2006 | 03:12 PM
dukman22's Avatar
dukman22
OK, so I ordered the Hellwig Sway Bar for the rear and the Energy Suspension Sway Bar Bushing kit for the front. It includes the end links and frame bushings. The end links had already been replaced but they come in the kit so I will replace them too. May be that will give me more of what I am looking for. I will post the results when its done.
Old Nov 16, 2006 | 04:26 PM
MOOK929RR's Avatar
MOOK929RR
can you send me the link to where you picked up the energy suspension kit for the front? I was looked for it, couldnt find....
thanks!
Old Nov 16, 2006 | 04:56 PM
pitrow's Avatar
pitrow
which bilstein shocks are you guys using? I'm getting ready to change out my shocks and don't want to throw money at junk. Also, I'm having a hard time finding shocks for the front of mine (4 corner LLS) any ideas on where/what will work?
Old Nov 16, 2006 | 05:15 PM
01silvergt's Avatar
01silvergt
Your gonna have a hard time finding anyone other than Ford that will offer a front LLS shock that is worth a damn (and thats not saying much). You can get Bilsteins for the rear. What do you drive?
Old Nov 16, 2006 | 05:21 PM
01silvergt's Avatar
01silvergt
Shocks install instructions
Originally Posted by 01silvergt
First off this is a 2000 Expedition E.B., with OUT LLS. I installed Bilstein Shocks on all 4 corners. Bilstein part numbers were as follows:
Front – BE5-2571
Rear – BE5-2573 (NON LLS)
(Rear-BE5-2572 (With LLS) for those that need it with LLS)
Tools Needed:
Small flat blade screwdriver
21mm wrench
20mm wrench
18mm wrench (2 needed)
¾” wrench
6mm allen wrench
13mm wrench
Optional tools:
21mm Deep socket wrench
18mm socket wrench
13mm socket wrench
SAFETY FIRST. Think safety all the time and work accordingly. Use gloves, and glasses at all times to protect yourself. Use wheel blocks to prevent the vehicle from rolling and use jack stands to rest the vehicle on. DO NOT rest the vehicle on the jack and get under it.
FRONT:
First jack the front of the truck up, and place jack stands under the frame rails. The higher you can go the easier shock removal and install will be. Also be sure to block the rear tires to prevent the truck from rolling back. Now I removed the front tires, to make access to the shocks easier, but you can also do the job without removing them, although it is much harder. After removing the front tires, spray the top nut and bottom two nuts of each shock with WD40. Give this some time to soak in. During this time I started to put the new shocks together, by this I had to thread the new rubber bushings provided onto the new shocks. Once I felt enough times had passed I went to work on removing the front shocks. I first used a small flat blade screwdriver undo the clip holding the ABS sensor line. I then tucked this line out of the way and unscrewed the clip from the top of the shock. Next I used a 13mm wrench (or a socket wrench) to loosen (do not remove yet) the bottom 2 bolts from the shock. Next I took my 21mm wrench and turned the shock so that I could get the 20mm wrench on the bottom nut on the shaft (there is an acess hole in the shock tower to get a 20mm wrench on the shock). Once the 20mm wrench was in place I was able to remove the top nut with the 21mm wrench. (Note: on the passenger side you can use a deep 21mm socket. On the drivers side you can not use a socket due to a bracket that sits just above the shock tower.) After I removed the top nuts, I then proceeded to finish removing the bottom nuts with the 13mm wrench. At this point the shocks should just slide out, you may have to angle them a bit to get them out. If you’re not high enough in the air you may need to compress them to slide them out.
Now comes the fun part of installing the new shocks. My truck was high enough to just angle the new shocks back in, but you may have to compress yours if you are not up far enough. Once I had the shock in the tower, I reused the 13mm bolts on the bottom and just put these in hand tight. Next I used a jack, placed under the shock to lift it up into the shock tower till the rubber bushing was pressing against the bottom of the shock tower. (I raised the jack till it started to lift the front end a bit) Next I installed the top rubber bushing and associated hardware provided with the shock. Be sure to use the nut provided with the shock on the Bilstein’s, as the old nut will NOT work. To tighten the new nut you will have to use a ¾” open end wrench, and hold the top of the shaft with the 6mm allen to prevent the shaft from spinning. I tightened to the good old German method of good-en-tight. As you tighten the new shocks in place you will notice the pressure will start to relieve on the jack as the bushings compress and the A-arms rise back in place. After I tightened the top nut, I removed the jack and tightened the bottom two 13mm bolts to manufactures specifications (good-en-tight). I then screwed the ABS line bracket back on the shaft and put the line back in place and clipped it back in. Before you put the tires back on, make sure all nuts and bolts are tight and to the proper specs, also make sure the ABS lines are positioned so that there are no kinks and that they will not kink when you turn the wheel. Remount your wheels and drop the front end.
REAR:
First block the front tires and jack the rear up as high as you need to get under the vehicle. (For me this is high, as I am fat) Place your jack stands under the rear axle on each side, and slowly let the truck rest on these. I also kept one jack in place to provide a triple redundant safety system from collapse. Next remove the rear wheels (this really is not a necessary step, but for me it was easier than trying to work under them, and I changed the rear pads at the same time). I then sprayed the top and bottom bolts with WD40, and gave them some time to allow it to work in. Now begin by using the two 18mm wrenches (or socket wrenches) to remove the bottom bolt from the rear shocks. Next you will need to remove the top bolt. On the driver side this was a real PITA, due to the fact that you could only access this with a 18mm open-end wrench, and turn it just a ¼ turn at a time. Thank god Ford decided to put a captive nut on it, so you only have to remove the bolt. (The drivers side is made easier if you access the bolt from over the top of the gas tank. You will need a few extensions, but this way is just as fast as removing the other bolts.) On the driver side the set up is the same, but you can use a 18mm socket wrench to remove the top bolt. After the bolts are removed the old shocks should just pull out. Install the news shocks in the reverse order. Some notes on installing the new shocks: I had to use a Dremel to grind off some of the top rubber bushing to get it to fit with the captive nut in place. You may or may not have to use a jack to compress the shocks to fit them in the bottom bracket. I was able to compress each by hand (very hard) and let them expand into place.
Hope this helps and hope some of you get good use out of this. I was able to ride in and drive this truck before and after the shock install and all I can say is WOW, these Bilstein's are really something else. I will be installing them on my 99 Expy with LLS, so stay tuned for a write up on this in the near future.
Some notes. The nut for the front shocks were 20mm on my 99 Expy. I was also told that Bilstein no longer uses a hex head bolt on the front shocks, they now have a standard set up (i do not know the size wrench needed for the nuts on these new ones).
Good luck and have fun, its easy to do.
Old Nov 16, 2006 | 10:26 PM
dukman22's Avatar
dukman22
Mook, Try this link and see if this what you are looking for. This what I ordered. Also try this same # at http://www.suspension.com/
http://store.summitracing.com/egnsea...115+4294841743
Old Nov 16, 2006 | 11:30 PM
djexpy00's Avatar
djexpy00
What diameter Hellwig sway bar should i go with. I found a 1" for 169$ and a 1"7/16 for 190$ at summitracing.com
Old Nov 17, 2006 | 04:11 AM
  #28
Greenscobie86's Avatar
Greenscobie86
I put Bilsteins on my 98 Expy. Probably the best upgrade I ever did. I would recommend them over anything!
Old Nov 17, 2006 | 08:08 AM
  #29
jrabenaldt's Avatar
jrabenaldt
I never saw the 1 7/16" option. The 1" bar was a noticible difference in itself.
Old Nov 17, 2006 | 08:23 AM
  #30
verticalrich's Avatar
verticalrich
shocks are very easy did it twice the sway bar sounds like a great addition
