Turn Signal
Old Nov 14, 2006 | 01:05 PM
Cowboy34's Avatar
Cowboy34
Question Turn Signal
i replaced the connector,taillight,brake light,turn signal and now my turn signal light will not work but my taillight and brake light works!! Could it be that i hooked the white and black wire up wrong?? the stock wireing is covered with a solid black coating so, i could not tell which wire is what except for the power wire.HELP!!
Old Nov 14, 2006 | 01:15 PM
Mil1ion's Avatar
Mil1ion
Brown is for Running lights/Tail-lights.
Old Nov 14, 2006 | 03:54 PM
Cowboy34's Avatar
Cowboy34
i figured it out,Thanks for the help!! Have you seen the headlight conversion ofr the 73-79 Trucks, i bought a set (Diamond cut,With replacement XENON Bulbs) and a heavy duty HeadLight wiring harnees.You should see the light they put out!! They are sold on EBAY! they are well worth it.
Old Nov 15, 2006 | 05:47 AM
trinogt's Avatar
trinogt
Yeah, thight lights look cool, but I wasn't aware they came with a harness... Does it include heavy wiring and an relay system?
I haven't seen them lit up.
My '78 has the Wagner poly lens. Very clear light, and break resistant. They have lasted me a very long time.
Old Nov 15, 2006 | 08:34 AM
Cowboy34's Avatar
Cowboy34
the ligyts, i bought off of ebay and the harness can be bought from LMC. The harness is heavy duty w/ two relayes, one for low beam,the other for high beam. a direct hook up to the old headlight harness!The lights have a city light under the main headlight bulb, which can be hooked up to the turn signal or park lights.
Old Nov 15, 2006 | 12:55 PM
Mil1ion's Avatar
Mil1ion
I think those are against the law here in Alberta.
The aftermarket doesn't care though.
I will be doing mine soon (in the spring) and I already use the Bosch Headlights 80w/100w bulbs.
Old Nov 15, 2006 | 01:46 PM
Cowboy34's Avatar
Cowboy34
They are DOT APPROVED!!!
