My driver's side arm rest is currently pointing straight at the floor. I assume there is a bolt or something come loose, or broken, any suggestions for fixing this before I get started?
GEt a differnt seat from a junkyard Aero, that would be an easier fix, and probably more durable, especially if the rest of the set is not in great condition.
You can tighten the arm rest by unzipping the cover and pulling it past the pivot point. You will see a large bolt. If the arm rest is dangling and you can't snug it up, it's probably damaged inside the seat... Look for a junkyard replacment seat.
Mine was the same way, it takes a Torx screwdriver, but you have to put the arm rest in the up position, and tighten it. I was real easy with presing on it, but it stayed in place.
