99 expy code po401
Old Nov 14, 2006 | 09:35 AM
fastpitch11's Avatar
fastpitch11
99 expy code po401
the truck has 130,000 miles it runs find never had a promblem can someone tell what i'm looking for
Old Nov 14, 2006 | 11:54 AM
01silvergt's Avatar
01silvergt
P0401 EGR Flow Insufficient Detected
Probably need to remove the t-body and clean out the two passages that go to the EGR tube. Your gonna have to get gaskets to replace the onve between the t-body and the upper intake, the t-body and the egr, and while your at it (if you have never cleaned or replaced the IAC) the gasket that goes there also. Take it all apart, clean it and you should be good to go.
Old Nov 14, 2006 | 11:57 AM
fastpitch11
thanks i'll give it a try
