I have a '72 F100 Sport Custom long bed with a 360 and a C6 and I need to replace the front part of the two-piece driveshaft. It has the bolt-up yoke on the back of the tranny and the slip-yoke on the back end. I'm having trouble finding the correct driveshaft at the local boneyards when I ask for parts for a '72. Most of the places here don't have data that go back that far. Is there another newer truck or van I can ask for that has the same driveshaft configuration?
Here are the specs I have on it right now?
-3" dia main tube
-16 spline, 1 3/8" slip-joint shaft
-24" length from center of u-joint yoke to center of carrier bearing.
-U-joint looks to be about 3 5/8" from from the end of each endcap to the other.
