Well can you describe the kind of idle problems your having????
Did the idle problem begin suddenly, after some event, or slowly over time????
Are you having any other problems that began at the same time, like driveability, accelleration, gas mileage change, warm or cold start probems, ect?????
We bought the truck for my son and it already had the problem.It runs good and starts up like nothing is wrong.I have notice the water temperature takes awhile to heat up.I'm not sure thats some of the problem too.As for the idling it feels like its surging and it does that in park or drive.
I disconnected the idle position sensor and the truck idles fine and the truck doesn't surge anymore.What I notice having the idle position sensor disconnected the tranmission shifts differently now.Now I think the idle positioner might be the trouble the whole time.
there's 2 things we talk about the IAC (idle air control solenoid) and the TPS (throttle position sensor) which one do you refer to?
I changed out the throttle positioner sensor and that cured the problem with the idle.I notice the potentiometer was really loose where it slips on the shaft.
Theres no more surging with the idle now.
Thanks for all the help.
