drain valve
Old Nov 13, 2006 | 06:42 PM
arcticoffroadingfish's Avatar
drain valve
hey just curious if anyone has bought a drain valve repair kit which is 5 orings basically. and how difficult it was to repair the valve? mine is leaking fuel out when closed so i bought the repair kit for it.
Old Nov 13, 2006 | 06:57 PM
Uzumati's Avatar
Uzumati
Common problem, you will only need two of them probably. The ones that seal the valve assembly to the filter housing. 1/4" socket and a T20 torx bit is the easiest there is not alot of room there
Old Nov 13, 2006 | 07:03 PM
thanks i think i will do that tomorrow at work if i can since i work at detroit diesel, rock on. thanks for the quick reply
