Sponsored by: Real Truck
front coil spring question?
Old Nov 13, 2006 | 05:33 PM
mjlevi's Avatar
mjlevi
My truck (an 05 F250 PSD model) has the 6000 pound coil spring set from the factory on it...from what I understand...a truck that has the plow package installed has the 6600 pound coil spring set,.. If I were to purchase this 6600 pound rate coil springs and install them, would it require a re-alignment of the front end?...and if I'm wrong about these numbers, please correct me with the right info, thanks !
Old Nov 13, 2006 | 09:32 PM
FortyFords's Avatar
FortyFords
Yes ,it would require a alignment.any time you mess with the physical demensions or a front suspension part it needs to be realigned.also after the new springs settle in ,it could/may need another one too.
Rich
Old Nov 13, 2006 | 10:49 PM
bneafus's Avatar
bneafus
I saw air bags for the front springs while surfing the other day. Might be an option.
Old Nov 14, 2006 | 06:49 AM
stewcon's Avatar
stewcon
Do you happen to remember where you saw them at?
Old Nov 14, 2006 | 08:57 PM
bneafus's Avatar
bneafus
Here's one example. Firestone's got a good rep with the guys on FTE.
http://www.ultimateautoaccessories.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=4160
Old Nov 15, 2006 | 03:31 PM
winged1dur's Avatar
winged1dur
If you have 6000lb. springs you already have the plow package. These springs will hold up a 1000lb. plow with no problem, but you will need at least 1000lbs. of ballast. The next step up in spring size are the 7000lb. springs used in the F450-F550. If you install these plan on wearing a mouthguard and helmet!
