Magnaflow Installed!
Old Nov 13, 2006 | 12:48 PM
Lawson4x454's Avatar
Lawson4x454
I installed the magnaflow SISO kit finally. I was kinda disapointed. The kit didn;t go all the way to the cat. Their is still 3' of stock pipe. And the sound is extreamly quiet even with my foot in it! Will it get louder with time?
Old Nov 13, 2006 | 01:09 PM
automaticj5's Avatar
automaticj5
It should open up a little bit -- I have true dual super 40 flowmasters and its starting to sound VERY NICE, about 1000 miles on the new exhaust now -- I am thinking of gutting my cats if it wont mess with the o2 sensors
Old Nov 13, 2006 | 01:26 PM
Lawson4x454
It will mess with your o2 sensors. But you can get something called o2 sims. It's chips for the o2 sensors that will fix the problem it causes. You'll have to shop around. I dunno where to get them.
Old Nov 13, 2006 | 01:28 PM
automaticj5
I c I c -- ok thanks -- Any other ideas of something to make it louder?
Old Nov 13, 2006 | 02:29 PM
is300wrx's Avatar
is300wrx
Shouldve have cut the OEM muffler off to see if you liked the sound. It's not obnoxiously loud, but perhaps it is what you are looking for. I went from a FLowmaster 40 series to a straight pipe. Will never go back!!!
Old Nov 13, 2006 | 03:12 PM
BigDfromTN's Avatar
BigDfromTN
I had a magnaflow installed. Just replace the factory muffler and used all same pipes. That was about 2-3 weeks ago. Mine seems to be louder now than it was when first installed. Give it a bit and I think you will like it more.
Old Nov 13, 2006 | 04:43 PM
Bob Jusnes's Avatar
Bob Jusnes
Magnaflows will break in over time.
O2 simulators are old school, if you get a custom X2 tuner, you can have the rear ones disabled.
Old Nov 13, 2006 | 04:54 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
should have gone with the SIDO, my truck went from quiet to roaring. there is also no point in gutting the cats, they already flow pretty good and won't restrict performance until you start pushing the 400+ hp range.
btw, put a nice 3" tip on the tailpiece, that will help in the sound department a little
Old Nov 13, 2006 | 04:57 PM
Lawson4x454
It came with a tip. 4" but the pipe is almost all the way through it.
Old Nov 13, 2006 | 05:33 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
extend the tip so only 2-3" of tailpipe is inside the tipe. basically just enough for the tip to be tightened down. it sounds like the tip doesn't have enough room for the gases to expand and resonate a little before they exit
Old Nov 13, 2006 | 05:36 PM
Ferguson65's Avatar
Ferguson65
The tip on the SISO is welded on. you unfortunatly can't adjust it. After a year you'll be looking to do something with it anyway as it will turn yellow and look like hell, just like mine!!!! Still haven't decided exactly what i want with it yet but, it will wait until after winter. I love the sound of my SISO. Loved it from the second i hit the key after I installed it. Maybe your used to a flowmaster drone?
Old Nov 13, 2006 | 06:43 PM
Lawson4x454
I'm just going to stick a torch in the pipe and cut it out! Good idea? haha
Old Nov 14, 2006 | 10:48 AM
MBBFord's Avatar
MBBFord
I'm thinking of just cutting off the stock muffler and putting a piece of pipe.
Could you please try and get me a sound clip of your truck, and rate how loud it is on a scale of 1-10.
1 being stock, 10 being no cats or mufflers(just straight pipe).
Thanks for any help
Old Nov 14, 2006 | 11:31 AM
bigmike610's Avatar
bigmike610
ive had the straight pipe setup and its nice, and ive also had it with no rear cats, THATS loud
with cats 7, without cats 9, 10 would be headers and no cats.
Old Nov 14, 2006 | 11:57 AM
is300wrx's Avatar
is300wrx
Thanks for any help
I cut it where the muffler was, and had a pipe bent to over the axle and dumped it there. compared to where I had it without the pipe being bent, the sound has dampened tremendously. From before having the pipes bent (same to where you would have to cut and replace it with the pipe), I would rate that a 10. I did this only because I initially had a 40 series welded on there, then I cut the whole thing off for like 2 days. Too loud. Now with a bent pipe in there, I would rate it a 7. Good luck
