The AC is stuck in defrost. It will turn off, change speeds, but will not move off defrost to vent or floor. I am thinking the door is stuck or the relay to make the door move is off. Any ideas or similar problems???
The AC system on the Expy is set to default to defrost if there is a fault in the system. usually it means there is a wiring problem or a vacuum issue. I found that the vacuum line coming out of the firewall had been chewed in two... We live in the country and I guess we had an issue with mice this fall... Anyway, the blend door issue is fixed....
