engine troubles
Old Nov 12, 2006 | 09:05 PM
jake47's Avatar
jake47
engine troubles
My truck (2.9L 90 Ranger) has always had a bad ticking sound. I used to think it was a lifter until tonight it got worse and worse until the whole truck started shaking at low speeds/low rpm. It starts kinda hard and has a horrible ticking/shake at idle. Also, when I got home, smoke was coming from the engine compartment. Any ideas
Old Nov 12, 2006 | 09:16 PM
RangerPilot's Avatar
RangerPilot
Ok don't try and run it again.
What color was the smoke? Do you see any obvious burning, leaking fluids, etc?
Old Nov 12, 2006 | 09:25 PM
jake47's Avatar
jake47
whitish blue smoke and no leaks or burning smell at the time, I will check more thouroughly for leaks in the morning.
Old Nov 14, 2006 | 04:50 PM
BSmitty's Avatar
BSmitty
I'm just taking a stab, but I'd guess a lifter collapsed due to wearing through the heel, and when collapsed it wont open the valve it's supposed to, causing a miss. Just a thought.
