High Idle
Old Nov 12, 2006 | 08:56 PM
SMiddleton's Avatar
SMiddleton
High Idle
Im new to the sight and need help on an engine problem. Just got my son's 87 F-150 with the 5.0 Ltr engine running after a three year sit. Runs OK except for some roughness probably because of gunk in the injectors but it idles very high. Don't have a tach on it but I suspect it's idleing around 1500-2000rpm. It's fuel injected. I've turned the adjustment screw on the throttle body as far to the low RPM side as it will go with no change. What else is there? Thanks
Old Nov 12, 2006 | 09:07 PM
Galizien's Avatar
Galizien
Sure there may be many things to look at,
But try taking off the idle air control valve and giving it a real good clean with carb cleaner. Should be located on the right side of the throttle body with a two wire connector comming off the top with 2 bolts holding it on the side.
Old Nov 12, 2006 | 09:22 PM
Wrench Turner's Avatar
Wrench Turner
That screw is not meant to be an adjustment. Try to return it to it's original position. You can sometimes see the rust mark on it from exposure to see where it was. My guess: vacuum leak. Check all vacuum hoses, I'll bet one gave up while the truck was in hibernation.
Old Nov 13, 2006 | 08:17 PM
SMiddleton's Avatar
SMiddleton
Thanks for the info, i'll check that
