header survey
Old Nov 12, 2006 | 07:31 PM
johaner78's Avatar
johaner78
Question header survey
Which set of headers should I use on a 1978 400 engine, .060 over, Comp. Cams #265DEH cam, roller rockers, Edelbrock Performer 400 non-egr intake, Edelbrock Thunder Series AVS carb 4 barrel, C6 tranny?
1) Hooker #6902, steel/ceramic coating, 1 3/4" primary/3" collector, 18 ga, 5/16" flange, tuned tubes, 90 day warranty.
OR
2) Hedman #89218, steel/ceramic coating, 1 3/4" primary/ 3" collector, 14 ga, 3/8" flange, tubes not tuned, lifetime warranty.
What do you guys think I should run?
Thanks
Old Nov 12, 2006 | 07:57 PM
T.R.Bauer's Avatar
T.R.Bauer
They both are good headers. I really doubt either is going to break. Get the one you want.
Old Nov 13, 2006 | 01:54 AM
f250rangerexplorer's Avatar
f250rangerexplorer
the heddman's have a lifetime warranty which is gonna be nice but the hooker's are tuned.... what matters more to you???? that should make your desicion.
Old Nov 13, 2006 | 04:48 PM
MBBFord's Avatar
MBBFord
The headmens have a little bigger flange, and are alittle cheaper, and will last just as long as a set of hookers will if not longer, but the only problem is, that ceramic coat isn't going to be the longest lasting thing out there, they might have a lift time garantee on the construction of the headers, but not the coating.
Old Nov 13, 2006 | 04:51 PM
MBBFord's Avatar
MBBFord
Also, just curious, why the ceramic coated headers?
I was looking for headers a while back, and wanted the ceramic coated ones, but new it wouldn't last much longer than a year if not less(from what I've been told). But I wanted to keep heat out of the engine bay too, but figured a set of $90 summit headers with header heat wrap would give me what I want, just not the looks, might be somthing to think about.
