vacumm lines
Old Nov 12, 2006 | 05:11 PM
wacky4speed's Avatar
wacky4speed
vacumm lines
i have an 88 f-150 4.9l and was wondering if any one could tell me what vacuum lines run to the vacuum canister "coffee can". thank you.
Old Nov 12, 2006 | 07:12 PM
srercrcr's Avatar
srercrcr
At a minimum you'll have at least one running to each fuel tank, capturing vapors. And then one to the intake area, pulling those vapors to burn them.
Old Nov 12, 2006 | 08:01 PM
wacky4speed
thats the charcaol canister.i meant the other coffee can shaped canister thats on top of the passenger side fender well.
Old Nov 13, 2006 | 07:40 PM
Torque9's Avatar
Torque9
The big silver colored canister on the passenger side wheelwell.The rear line off of the can goes to a round metal vac T coming off of the pass. side of the intake.It points to the pass side and looks like a hex shaped piece of pipe threaded into the intake.The other one looks like it is routed under the intake around to the vac solenoids(for what I don't know) on the driver side right above the cyl. number 6 spark plug.I went out and looked at mine just now.It's dark but I tried to chace the lines down as best I could.Mine is an 88 F-150 300 auto so they should be the same
Old Nov 13, 2006 | 10:21 PM
dropshadow's Avatar
dropshadow
hey i got a 91 efi 6 and the coffee can lookin thing on my pass side fendwr well has a big hose comin from it goin to nothing and another one goin to some pump lookin thing on the motor. and i dont believe there is anything else hooked up to it. am i right or wrong? anyone kno what it is?
Old Nov 14, 2006 | 03:15 PM
bhbh's Avatar
bhbh
I believe that's the vacuum reservoir, used to keep steady vacuum to the EGR and thermactor solenoids.
