89 Ranger possible transmission problem
Old Nov 12, 2006 | 02:47 PM
razormac's Avatar
razormac
I have just bought an 89 Ford Ranger with a 2.9l v-6 automatic trans. I was told the transmission had been rebuilt. I know the transmission guy and he does good work. It seems that the gears shift fine when giving it the gas at a quick pace. When I do a slow take off going through the gears the shifting is smooth until I reach the speed of 35mph. It thens feels like the transmission is slipping or surging. Once I speed up past 35 mph the surging stops. I was told it could be the torque converter? Any help would be appreciated.
Old Nov 18, 2006 | 05:41 AM
razormac's Avatar
razormac
Someone please help?
Old Nov 18, 2006 | 03:01 PM
87 XLT's Avatar
87 XLT
Convertor locking/unlocking??
Try this, press on the brake pedal just enough so the brake lights come on, That will keep the convertor from locking. Any difference?
Or, what happens if you lock it in a lower gear?
Old Nov 19, 2006 | 08:03 AM
razormac's Avatar
razormac
Smile
Thanks...Pressing on the brake lightly did help. I wonder what something like that would cost to get fixed? Would the transmission need to be rebuilt again?
Mike
Old Nov 19, 2006 | 12:10 PM
87 XLT's Avatar
87 XLT
One quick & simple thing that you can do is to pull the codes & see if the computer can tell you what the problem is.
I took a quick look a the list of trouble codes in my scanner manual and a code 89 "lockup solenoid circuit failure" might fit your symptoms.
Edit
BTW, have you checked with the trans shop that did the rebuild? Maybe theres some time left on the warranty.
Old Nov 19, 2006 | 12:54 PM
razormac's Avatar
razormac
Thanks I really appreciate everything!!
Cobra-Kai
69
Dec 21, 2013 10:28 PM
kellie
1978 - 1996 Big Bronco
Dec 29, 2010 02:09 AM
chargedstang89
1997 - 2003 F150
Oct 27, 2005 03:08 AM
wtrdog
Mar 30, 2004 03:38 PM
