I have been sitting on a fence post about this for quiet some time I have a 79 supercab and I am thinking of putting the cab on my 78 bronco frame I realize there will be some carnage. My question to all of you is have any of you pondered this or have any of you tried this or done it any comments or info will be greatly appreciated
Helpful hint to you maybe ? If you edit your thread title within the next 56 minutes to something like, " 79 Supercab body swap possible ??" you may get more replies. good luck with it,
the frame may bend up or down to make room for a supercab on a supercab-frame, which is different than a bronco frame. So you'll likely be looking at a lot of work other than just putting the cab on a bronco frame. Same goes for a crewcab w/shortbox on a supercab frame(with longbox), doesn't work cuz the frames are different.
I know that I've seen a supercab with either the rear box area shortened wwaayy up, or it was a supercab cab sitting on an already short chassis (Bronco, Short bed reg cab 1/2 ton). It looked like it would be sweet for the trail.
I was out in the snow taking some measurement's and the verdict is that I will have to cut the wheelwells into the rear cab bottoms approxamately 14" in from the back also the rear cab mounts are iether going to just fit or are going to need some fine tuning either way its going to be some work but I think Im going to Try it
mainly just because ok seriously I think its never been done or at least not documented in these forums also I think it would be really cool to have and to drive if the body is done right all straight and no short cuts
Ill try to post the pics i made with ms paint
I am thinking you will have your work cut out for you being an 89 frame I suppose the width of the frame is an issue for the cab eh now that I am thinking about what you are doing and I am liking it in fact , if and when i finish my SuperBronc I am going to try your idea I am thinking of theroad handling and economics of driving on the hwy the 89s have overdrive right
I think you might have been sitting on that fence post TOOOOOO long and it might have gotten fer enough up there to scratch your thinging spot. LOL To much work for me to think about. You have got to take pictures.
I have walked away from good deals before and kicked myself in the rear end. I know this is a non friendly chevy site, but 2 years ago I had the chance to buy a very straight and clean 69 chevy 3/4 ton 4x4 that was in nearly perfect original condition with a 8,000 pound warn winch, KC driving lightsm a 4 speed trans, an np205 tc, and dana 60s in front and rear. I took her for a spin and it ran great. You tell that the owner (it was the original owner) really took care of it. He only wanted 3,600 dollars for it and it only had about 80,000 original miles. I went home to think about it because I have 3 pickups and really didn't know where I'd put another finished project. The next day it was gone - a dealer bought it. I think with a paint job (there was vitually no rust or dents) it would fetch 12,000 grand today. I should have offered him the cash right then - what was I thinking?
