speedo problem
Old Nov 12, 2006 | 12:03 AM
12savage's Avatar
12savage
speedo problem
I have a 95 f-150 4.9 5 speed. When it is warm outside the speedometer and odometer will not work until the A/C cools the cab down. Also if I push in on the odometer switch the speedometer and odometer will come on and work fine. When I let off of the switch they go off. Any suggestions on what is wrong.
Old Nov 12, 2006 | 09:14 AM
subford's Avatar
subford
I would look at the PSOM and its plugs also the gear indicator can cut into the ribbon cable from the PSOM to the odometer.
