Adding 12 volt outlet
Old Nov 11, 2006 | 11:21 PM
ndfordfan's Avatar
ndfordfan
Question Adding 12 volt outlet
I would like to add another 12 volt outlet in the cab of my truck for a XM radio, how do I do it? I have 1999 F-150 Extened Cab if that makes a difference. Thanks.
Old Nov 12, 2006 | 02:16 PM
Franklin2's Avatar
Franklin2
The radio doesn't draw much power, so you should be able to splice into the outlet you have now, and run to another aftermarket outlet mounted under the dash.
