Copper bearings?
Old Nov 11, 2006 | 08:46 PM
deadman-v's Avatar
deadman-v
Copper bearings?
Anyone run into these? During this last engine swap I did a re-seal of a '70 429. I popped the rod and main caps to check clearance and found them to be copper,.... NO babbitt. At first I thought they were just competely shot, but they miked within spec. They also have a C9 year code and are at standard.
Its just curiosity at this point. I ended up using them with no problems... 45 lbs. hot at idle with 10-30 oil.
Any info would be great! Thanks guys!
Ron
Old Nov 13, 2006 | 03:47 AM
airharley's Avatar
airharley
This site might shed some light on it a little.
http://www.aa1car.com/library/2005/eb030526.htm
Old Nov 14, 2006 | 11:54 AM
deadman-v's Avatar
deadman-v
Thanks for the info! Something to look into when I plan the next rebuild....
Old Nov 15, 2006 | 05:55 PM
Barry_R's Avatar
Barry_R
Thats a good article - - but they spelled my name wrong!
It's Rabotnick - not Robotnek!
BTW - the copper showing indicated wear - but does not really mean damage. The tin overplate that gives the silver color is only a half thou thick - your measuring equipment might not even pick it up...
