blinkers not working
Old Nov 11, 2006 | 03:15 PM
ryly's Avatar
ryly
Hi,
I recently developed a problem with my blinkers. They don't work; there is no flashing, and no indication of flashing on the dash. At the same time, my cruise control, hazard lights, and brake lights stopped working. I replaced a few fuses, now the cruise control, brake lights work. I sprayed wd-40 on the hazard light switch, which started to work. Nothing I did would get the blinkers to work. I replaced the multi-function switch, which also didn't help. Could this be a relay problem or grounding issue?
Old Nov 11, 2006 | 04:07 PM
quicklook2's Avatar
quicklook2
the hazards and the blinkers have two different relays. one on the front of the fuse box and one on the back.
Old Nov 11, 2006 | 09:49 PM
ryly's Avatar
ryly
Thanks for the response. Are you referring to the instrument panel fuse box or the power distribution box?
Old Nov 11, 2006 | 09:55 PM
quicklook2's Avatar
quicklook2
the fuse box is inside the cab.
that is the one i am referring too.
