Aerostar Ford Aerostar
Rear Brake Hose Replacement?
Old Nov 11, 2006 | 02:52 PM
Aftrmidnite's Avatar
Aftrmidnite
The Rear Brake hose has a large hose, with a one time hose clamp, coming out of the rectangular fitting block and goes into the frame. What is this hose for, how does this fitting work? As it seems this is how the block is mounted to the axel.
Old Nov 11, 2006 | 05:47 PM
Aftrmidnite
Never mind on this, I figured out its the breather for the rear axle housing, got it apart without breaking the "hollow" bolt. Have another problem, should have known better than to be able to do a complete brake job in a day.
