Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Split shift
Old Nov 10, 2006 | 09:41 PM
Snowking's Avatar
Snowking
Split shift
My 51 has a split shift rear end and most pieces by the motor, but my question is where does the split shift **** mount and is it a turn style or the modern "red button" style.
Thanks, hopin I'll have eight gears soon, Ryan
Old Nov 11, 2006 | 09:24 AM
51dueller's Avatar
51dueller
Unless the axle has been swapped it should be vacuum controlled. Here's some pics that should help you out.
Shifting it is just like any other 2spd rear axle.
Old Nov 11, 2006 | 10:03 PM
Fullcrew7.3's Avatar
Fullcrew7.3
I wish my '52 had a splitter. Not to mention my '86, and my '96!
Old Nov 13, 2006 | 10:32 PM
preppypyro's Avatar
preppypyro
Splitters are nice, ya manage to get it to work yet?
Old Nov 14, 2006 | 08:18 PM
Snowking's Avatar
Snowking
No not yet, A split shift would be cool on a pickup
Thanks dueller it's all hooked up except for the control
Old Dec 10, 2006 | 06:42 PM
Snowking's Avatar
Snowking
Here's a long shot does any know what that button looks like would the newwer red plastic style look out of place.
Old Dec 10, 2006 | 08:35 PM
Fomoko1's Avatar
Fomoko1
The newer shift controll buttons are made for electric two speed controls, older trucks used vacuum controlled two speed rear axles. You maybe able to use some type of a vacuum switch.
Old Dec 10, 2006 | 09:56 PM
Snowking's Avatar
Snowking
We have a selector from a GM it's kinda unique because you srin a rod in a half moon shape. I would half to turn or replace that Check and control valve assembly
Old Dec 11, 2006 | 04:42 PM
DonMckay's Avatar
DonMckay
Ryan, from looking at the page that Nathan has posted it looks like the control is a black choke control cable that is mounted in the dash. I know that on later years it was mounted on the gearshift lever.
Don
49fordv8f4
Apr 2, 2017 05:57 PM
MrHandsome
Dec 16, 2016 09:01 AM
bigcrunch
Large Truck
May 23, 2016 08:18 AM
fatheroftwo
Feb 14, 2016 12:46 PM
Rusty's92
23
Dec 13, 2010 07:46 PM
