engine swap newbie question here
Old Nov 10, 2006 | 05:01 PM
notlowyet's Avatar
notlowyet
I am picking up a 93 302 HO from a TBird and am swapping it into my 88 Mazda, and changing it to carburated. On that alone, emissions is not a problem around here. My question is, its coming with an AOD tranny and I was wondering if there was any wiring that would have to be rigged up, or could it just hook up?
Old Nov 10, 2006 | 07:51 PM
crash12884's Avatar
crash12884
the only wiring you should have to deal with would be for your neutral safety switch and your reverse lights which all you would have to do is splice them into your original wires... hmmm mazda it may not be tranny sensors ... but i dunt see why it wouldnt be
TigerDan's Avatar
TigerDan
I'm not really much of an expert on automatic transmissions and usually try to avoid them, but from what I understand the later AOD tranny (actually called the AODE) is computer controlled. If you are set on using that transmission in a carbed application, there are kits for doing so that require a stand-alone computer to control the tranny, but I understand they're a bit pricey.
Check out this site for some AOD TV linkage info:
http://www.becontrols.com/tech/tvlinkage.htm
Old Nov 10, 2006 | 08:21 PM
notlowyet's Avatar
notlowyet
so I should be looking for an AOD instead of the AOD-E, correct?
Old Nov 10, 2006 | 09:38 PM
TigerDan's Avatar
TigerDan
That would be a better bet if you want an O/D automatic. I'm not sure what years they were available before going to computer control, but I've seen them as early as 1980 so I'd look for a mid to late '80s model.
Old Nov 10, 2006 | 11:13 PM
notlowyet's Avatar
notlowyet
thanks for the help Dan, as you can tell, I'm kinda new to this aspect of the workings
so I'm sure there will be plenty more questions to come
Old Nov 11, 2006 | 05:57 AM
HemiEater's Avatar
HemiEater
ckeck in here ...might help
http://64.233.161.104/search?q=cache...++4T60-E&hl=en
looks like they started the AODE in 94
Old Nov 11, 2006 | 08:43 AM
TigerDan's Avatar
TigerDan
Well, that chart only shows the AODE behind a 3.8 V6 in the T-bird from '92-'94, and shows an AOD as about the only other possibilty for '93 so you might be good to go.
I just pulled a roller 5.0 from a '93 'Bird a few months back, but I paid no attention to the tranny. The wiring on that thing was a nightmare, it doesn't have a stand-alone ECU/engine control harness like the Mustang, it's all integrated into the car as the computer runs virtually everything. So it's not a bad idea to go carbed for your swap, unless you were to get a Mustang or aftermarket harness. EFI isn't really that bad to work with, I'm going EFI in my Ranger.
