Did a Bad Thing
Old Nov 10, 2006 | 02:45 PM
E30tdf's Avatar
E30tdf
Did a Bad Thing
I feel like an idiot, but, we all make mistakes!
I installed my battery backwards (+ cable to - term, and visa versa). Before I did that the engine cranked ok, but my fuel pumps were not working.
Now, it won't even turn over. So I replaced the starter relay. That didn't help. The fuses in the fuse box are all good.
What have I likely damaged? Is there an inline fused link I have likely fried?
Dumb Me
Old Nov 10, 2006 | 07:05 PM
Franklin2's Avatar
Franklin2
What year are you working on? Depending on that, yes you may have some fusible links that are burnt in two.
Go back to the starter relay. Look at the large terminal that goes to the battery +. On that same terminal with the large bat wire, there should be one or two other smaller wires. These power the whole truck. Follow these smaller wire(s) down, and you should run into some colored rubber things in the wire. These are the fusible links. If you keep following the harness, you may find some more down the line were the power splits off to feed other parts of the vehicle.
Old Nov 10, 2006 | 07:17 PM
E30tdf's Avatar
E30tdf
This is an 1986 F250 with Duraspark II ignition. Carberated 460. Should I untape the wire harness to find these fusible links?
Old Nov 10, 2006 | 07:20 PM
E30tdf's Avatar
E30tdf
What I did, reversing the terminals would send power directly to the starter solidoid which is part of the starter, would it not? And the other side would be grounded. So I thought it was probably the relay. But no!
Old Nov 10, 2006 | 09:05 PM
Franklin2's Avatar
Franklin2
You should have a fusible link right there at the starter relay. If not, then you might have to follow the harness down some to find them.
The starter relay large terminal that goes to the battery + is the spot where the factory hooks to the bat + for all power to the truck. This includes the alternator. There is a chance you have run current through the alt backwards, burning it up too. But you won't know that till you get the fusible links fixed to repower the truck. If the fusible link burnt in time, you might not have any trouble at all.
Old Nov 11, 2006 | 09:05 AM
Paul_1966's Avatar
Paul_1966
It will certainly have resulted in a high current through the alternator, as the rectifier diodes will have been forward biased in chains of two across the reversed battery. If you're lucky, the fusible link will have blown before the high current had a chance to take out one or more diodes.
Old Nov 11, 2006 | 10:04 AM
E30tdf's Avatar
E30tdf
Would the alternator burnout cause a break in the circuit such that the starter would not get any power to turn it over?
Old Nov 11, 2006 | 10:14 AM
subford's Avatar
subford
No it would not.
Old Nov 11, 2006 | 10:19 AM
subford's Avatar
subford
With this system you have two small terminals on the starter solenoid, if you get those reversed it will not crank.
One of the small terminals goes to the fuel system and the other goes to the Ignition Switch byway of a safety switch.
Old Nov 11, 2006 | 10:34 AM
E30tdf's Avatar
E30tdf
Then, I'm inclined to think it took out something in the starter, ignition, run circuit. Is it obvious from a visual inspection that the fused links are blown?
Old Nov 11, 2006 | 11:00 AM
subford's Avatar
subford
If you put one hand on each side of a fuse link and pull and it stretches it is bad.
Also if you jumper a wire from the POS side of the battery to the small terminal of the starter solenoid that had the red wire with a blue stripe on it the engine should crank.
Make sure it is out of gear or in park when you do this.
Old Nov 12, 2006 | 05:18 PM
E30tdf's Avatar
E30tdf
By using a volt meter I have determined that at least one fused link is damaged in the harness to the alternator. With the wire coming off the hot side of the starter relay terminal I checked for voltage at the alternator terminal and there was no voltage.
So assuming that the fused link is blown, does one just patch in a new fused link, or go to Ford for a new harness (at least that portion going to the alternator)?
Old Nov 12, 2006 | 05:37 PM
subford's Avatar
subford
You just patch in a new 14 GA fused link. Any auto parts store should have them.
Old Nov 13, 2006 | 08:47 AM
E30tdf's Avatar
E30tdf
Thanks for the help Subford. Electrical is not one of my best skills. Tom
Old Nov 13, 2006 | 09:13 PM
E30tdf's Avatar
E30tdf
Unfortunately here in WA it is getting dark by 5:00 PM now and this rig is outside. Also it is raining (what RAIN in Seattle area....what a surprise) as this is probably the wettest month. SO, it may be a while until I get to work on the truck. Thank goodness this is NOT my DD. Thanks to all!
