pulling lifters
Old Nov 10, 2006 | 02:21 PM
TKKTommyboy's Avatar
TKKTommyboy
pulling lifters
is it possible to pull lifters with a magnet without taking off the intake?
not sure if they will fit through does anyone know? god i hope so. its a 390 with a stock 4 barrel intake.
Old Nov 10, 2006 | 02:42 PM
Freightrain's Avatar
Freightrain
All I can say is.......Good luck. Most times you'll never get them all, if any. I don't think there is enough room to get them thru pushrod slots anyway.
Save the cuss'n and just pull intake. Another hour wasted is better then days cuss'n.
Old Nov 11, 2006 | 05:02 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Nope..Yeah aint gonna gettem thru the pushrod holes!!!
RJ
Old Nov 11, 2006 | 08:07 PM
LedheadELH's Avatar
LedheadELH
I'm w/ Russ on this one...DEF need to pull the intake
Old Nov 11, 2006 | 08:56 PM
baddad457's Avatar
baddad457
It CAN be done, but it ain't easy. If you're talking about one, two, three or so, it's not too bad, but if you're trying to replace all, pull the intake. And this ONLY applies to FE's. With other engine families, I don't think any have large enough pushrod holes to handle a lifter. FE's have got large open gaps between the intake and heads to pass lifters thru.
Old Nov 11, 2006 | 09:52 PM
LedheadELH's Avatar
LedheadELH
what's so bad about pulling the intake anyways?.....it's only a few bolts, and a distributor....that's worth the time saved pulling lifters out to me.....but who knows
okay, so I left out some coolant lines....not that it makes much of a difference...
Old Nov 12, 2006 | 06:49 AM
RapidRuss's Avatar
RapidRuss
Well Bdad,
I guess it could be done if your a surgen...LOL..Because those opening on the Intake are not inline with the lifter bores, and would haveto be fished out at an angle..
and I think the inner most lifter's might not clear the Hold down boss's for the covers?
Just pull the Intake and be done with it!! you would spend so much more time in the long run fishing lifters out of the Valley than its even worth..JMO..
RJ
Old Nov 12, 2006 | 07:02 AM
baddad457's Avatar
baddad457
UH, What's so bad? If you've got a 100 lb iron intake, that's what comes to my mind. Fishing those lifters not inline with the openings in the intake isn't as hard as you'd think. As long as they're not varnished up or damaged in some other way that would keep them from coming out of their bores with a magnet, it's not that big a deal to do a couple.
Old Nov 12, 2006 | 07:22 AM
xfordman's Avatar
xfordman
I pulled one the other day just to see how it was wearing. As it came out I realized that if it lost contact with the magnet it would fall under the valley pan. That was one I could see, most of them I couldn't see.
Old Nov 12, 2006 | 10:30 AM
LedheadELH's Avatar
LedheadELH
yea, I dunno, I've never had lifters that just lifteed right out, they usually have varnish on the underside, so I've always had to pry at em' w/ something. and that 100 lb intake's not that bad, I've taken em' off, and put em' back on in my truck before.....it wasn't as friendly as the 302 intake in my Ranger, but it still wasn't TOO bad.
