Sponsored by: Auxito
P0401,P402 codes
Old Nov 10, 2006 | 09:51 AM
97texan's Avatar
97texan
P0401,P402 codes
I'm trying to find a fix for these codes on a 97 F150, 5.4L
Old Nov 10, 2006 | 10:01 AM
macjb's Avatar
macjb
Here is a link. Then do a search.
https://www.ford-trucks.com/article/..._Controls.html
Old Nov 10, 2006 | 10:18 AM
97texan's Avatar
97texan
Egr
With engine running, I pulled off line going to EGR Valve and applied vacumn, the engine tried to die.Does this mean the EGR valve is good?What next?
Old Nov 10, 2006 | 11:13 AM
LEVEL10's Avatar
LEVEL10
try looking into http://www.obd-codes.com/ this site can help you find what the code is and how to check it out
Old Nov 10, 2006 | 11:41 AM
Bluegrass 7's Avatar
Bluegrass 7
Hello Level 10, If you are not SAM, tell him and the boss I said hello and that my trans is working fine. It's the custom built towing job your shop done with the diesel converter in a 4r70w, out of a red 02 super crew from Pa..
Old Nov 10, 2006 | 11:45 AM
Bluegrass 7
97, look at the hoses and stand pipe the DPFE is connected to for cracks , rust etc.
If ok, the DPFE is highly suspect.
Both codes togather suggest this.
z 97ford1
1997 - 2003 F150
Nov 28, 2009 12:09 PM
Ultramagdan
1997 - 2003 F150
Jul 15, 2002 06:55 PM
Sid06
Apr 8, 2002 12:57 PM
