vacuum problems.powersteering whinner
Old Nov 9, 2006 | 08:57 PM
flattop101's Avatar
flattop101
Exclamation vacuum problems.powersteering whinner
i have a 89 f250 custom 4x4 5.8efi and auto trans i am in need of the complete and detailed vac diagram the one under hood not detailed and unreadable the one from haynes not complete can someone plz help,also powersteering whine it did leak took apart fixed leak replaced fluid, still a whinner any home remedies known or additives known to work
Old Nov 9, 2006 | 09:09 PM
theman79's Avatar
theman79
a place to look
i don't know where to look on the web but your local library usually has a huge set of repair manuals that are more complete than chilton or haynes.
Old Nov 10, 2006 | 09:25 AM
Kemicalburns's Avatar
Kemicalburns
to fix the whine you need to locate a Saginaw ps pump from a fullsize van with the same motor you have. get the bracket , and hoses as well. this will fix that and provide better steering as well with larger tires.
