Cigarette lighter
Old Nov 9, 2006 | 06:42 PM
MO51's Avatar
MO51
Cigarette lighter
After 20 years, I thought it was time I wired up the new aftermarket "cigarette" lighter on my 12V 51f1..for cel phone. I rewired my truck with OEM type wiring years ago, just left the cigarette lighter wire dangle. When I now go to connecting the female red wire to the lighter's male bayonet, I get sparks. Maybe the aftermarket "lighters" assume they'll be mounted in a plastic dash, rather than the 51's OEM hole in metal dash? What am I doing wrong? Gene in Sacramento
Old Nov 9, 2006 | 10:40 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'd suspect the male terminal is a rivet thru a hole in the shell, with a phenolic washer to insulate it. I'd bet the phenolic isn't working. Check with an ohmmeter.
Old Nov 10, 2006 | 05:47 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I have the same type lighter and mine works fine. You did convert to negative ground when you went with the 12 volt system, right?
Old Nov 10, 2006 | 10:00 AM
MO51's Avatar
MO51
negative ground-cig lighter
Yes, I have negative ground system. Your posts have helped me. The problem with my lighter hook up has been located between my ears. I should be hooking the hot wire to the center screw of the lighter, and instead I was trying to hook it to the outer housing, which conveniently has a male spade, probably put there for grounding purposes. Duhh. Thanks all, for kickstarting my brain. Gene in Sac'to.
Old Nov 10, 2006 | 10:04 AM
GreatNorthWoods
Ah yep, hooking 12V to a ground spade will get you sparks every time.
Glad you found the problem.
Old Nov 10, 2006 | 01:36 PM
Evans 1505's Avatar
Evans 1505
I am glad to see I am not the only guy that has a brain fart.
Old Nov 10, 2006 | 06:21 PM
AXracer's Avatar
AXracer
FYI: You can now buy housings without elements with a rubber cap if you are just using it as a power source. I have 4 I plan on putting in Gracie. You can never have too much power! huuuh huuuh huuug!
Frmnsal
15
May 28, 2018 04:04 PM
Tomget
Jul 24, 2016 09:29 PM
Poor'it in'her
May 5, 2014 09:53 AM
1979 300i6
Jul 20, 2013 09:04 PM
ten70man
1997 - 2003 F150
Nov 11, 2010 12:12 AM
