Sponsored by: Real Truck
possible trannie problems
Old Nov 9, 2006 | 05:40 PM
suzuki0702's Avatar
suzuki0702
i ahve a 2004 f250 crew cab fx4 5.4 3.73 23000 miles..not sure if its the trannie..but what im having trouble understanding is..when i get on the gas pretty hard...i think its in 2nd gear and up i mash the peddle and it goes up to around 3000rpms, and while im watching my tach it bogs down a notch on the tach and then climbs back up.. to around 3000.is this normal...is that redline? anyone have similar problems? ive got 9 months of factory warranty...also when im driving i will step on the gas and itll go into lockup on the converter and then the rpms will drop down 120-200 rpms..almost like its slipping? anybody make anything of it? ...sucks i dont have the search bar anymore...thanks for the help fellas!
Old Nov 9, 2006 | 06:12 PM
ReAX's Avatar
ReAX
Try using google with the following before your search terms site:ford-trucks.com
If you are at WOT and the engine will rev only to 3K, you have other issues. I have noticed that each gear will go into to lockup and my tach drops 100-150rpms. With my mods it feels like another shift. My 5.4 hits a rev limiter around 5400 rpm.
Have you done the regular maintance stuff like fuel filter, air filter, ect?
Old Nov 9, 2006 | 11:08 PM
John311t's Avatar
John311t
Sounds like TC lock up to me. But if the 5.4 doesnt go over 3k than you got a problem.
Old Nov 10, 2006 | 09:57 AM
bryyce62's Avatar
bryyce62
Yeah, TC lockup.
Right when you get on the gas, it picks up nicely, then right at 3K it drops to about 2600 RPM right? then back up again. Doesn't really feel like a shift, kind of a bog. On mine, if you hit the gas real hard it doesn't lock up in 2nd. Inclines and loads affect the shift point also.
Normal operation...unfortunately. It'd be nice to have the TC only lock up when it gets to overdrive.
Old Nov 10, 2006 | 07:42 PM
suzuki0702's Avatar
suzuki0702
Originally Posted by bryyce62
Yeah, TC lockup.
exactly..so whats the deal with it? should i send it to the shop or should i keep driving the thing ? will it affect my integrity of the truck?
