How to program a replacement PATS key....
Old Jul 19, 2012 | 04:08 PM
Locksmith1's Avatar
Locksmith1
Not cloned then... Get a 3rd key now or if you loose one, you be back at the locksmith again... 3rd key can be programmed w/o computer... Cheaper !!
Old Jul 19, 2012 | 04:09 PM
Locksmith1's Avatar
Locksmith1
Cloned keys can be identified by " contains battery " on head of key
Old Jul 19, 2012 | 04:10 PM
fenderpicks's Avatar
fenderpicks
Thanks man, thats good to know... it costed me 135$ for a 20 min job!!
Old Jul 19, 2012 | 04:16 PM
Locksmith1's Avatar
Locksmith1
Ur welcome... That's about right.. Remember, it's cost him 5000. For that machine !
Old Jul 19, 2012 | 04:18 PM
Locksmith1's Avatar
Locksmith1
FYI... Non cloned keys... Part nmbr h=ford/Mazda. Xx = model specific p= plastic head t=transponder. Ie ... H72pt
Old Jul 19, 2012 | 04:20 PM
Locksmith1's Avatar
Locksmith1
5200 for my machine + 1700 / year for updates...u didn't get ripped off
Old Jul 17, 2016 | 04:16 PM
Jeanette.1960's Avatar
Jeanette.1960
[QUOTE=allenpryor;8964882]I can't manage to get my original key to work, I see that mazdarangerguyinstl said it would work for the b3000 but which one? programming method b or c? I've been trying method b but it doesn't blink for 15 minutes, only for a little over thirty seconds, the it starts this one beep, three beeps thing for another thirty seconds or so, then stops. I don't know what to do about this.[I am trying to program a new key to a 1999 expidition
Old Jul 17, 2016 | 04:41 PM
Locksmith1's Avatar
Locksmith1
[QUOTE=Jeanette.1960;16430244]
Old Jul 17, 2016 | 04:42 PM
Locksmith1's Avatar
Locksmith1
[QUOTE=Locksmith1;16430284]
How many working keys do you have now? Blank part number H72PT?
Old Jul 17, 2016 | 05:50 PM
Jeanette.1960
None lost the origials
[QUOTE=Locksmith1;16430288]
Old Jul 17, 2016 | 05:53 PM
Locksmith1's Avatar
Locksmith1
[QUOTE=Jeanette.1960;16430399]I don't see your reply.
Old Jul 17, 2016 | 06:23 PM
Locksmith1's Avatar
Locksmith1
[QUOTE=Locksmith1;16430406]
Oh, there it is..
If you don't have any keys programmed you will need a locksmith To come to the vehicle to program 2 keys. This is assuming that keys you have are cut and will turn.
The 15 min thing has never worked for me.
Old Jul 17, 2016 | 06:35 PM
  #28
Locksmith1's Avatar
Locksmith1
[QUOTE=Locksmith1;16430461]
Oh, there it is..
If you want to email me, then I will give you my phone number. At least I can give you an explanation of how it works.
Old Nov 22, 2016 | 06:03 PM
  #29
Auggiedoggy's Avatar
Auggiedoggy
2011 Ford f150 new fob key starts engine, but won't lock unlock doors
Originally Posted by BearMan54
These instructions will save you a lot of money. The dealer wants at least $50 just to do this simple procedure.....
To start off, I'll explain a bit about what a PATS key is, what it does, and why this might concern you.
PATS is an acronym that stands for Passive Anti-Theft System (Ford also calls this SecuriLock). It is also called a transponder key. It is a security feature found on most (if not all) new Ford products, and what it does is disable your vehicle's starter unless your specially programmed key is used to start the vehicle. There is a computer chip inside of the key, and without that you will NOT be able to start the vehicle -- even if you have a regular (non-PATS) key with the correct cuts, it will not work.
For convenience, I'm also including a list of other vehicles that these instructions apply:
<TABLE style="BORDER-COLLAPSE: collapse" borderColor=#111111 cellSpacing=1 cellPadding=2 width="90%" align=center border=1><TBODY><TR><TD vAlign=top noWrap width="50%">Ford Contour ‘98–up
F-150 ‘98-up
Ford Crown Victoria ’97-up
Ford Escort 99-up
Ford Excursion ‘00-up
Ford Expedition ‘98–up
Ford Explorer ’98-up
Ford Focus ‘00-up
Ford Mustang ’96-up
Ford Ranger ’98-up
Ford Taurus ’96-up
</TD><TD vAlign=top noWrap width="50%">Ford Windstar ’98-up
Lincoln Continental ’98-up
Lincoln LS ’00-up
Lincoln Mark VIII ’98-up
Lincoln Navigator ’98-up
Lincoln Town Car ’98-up
Mercury Grand Marquis ’97-up
Mercury Mountaineer ’98-up
Mercury Mystique ’98-up
Mercury Sable ’96-up
</TD></TR></TBODY></TABLE>
NOTE: These instructions may apply to more or less vehicles than those listed above. I cannot confirm that these procedures work for every year and model listed. See your dealer if to confirm this.
<HR>On-Board Programming Method "B"
for Ford keys (1996 -early 1998 Ford, Lincoln, Mercury)
If you want to initiate a new master key....
1. Insert new key into ignition cylinder and turn it to the ON (RUN) position. The security light on the dash will flash for fifteen minutes.
2. When the security light stops flashing, you have FIVE minutes to start the next step. Turn the ignition cylinder OFF and then back to the ON (RUN) position. The security light on the dash will flash for fifteen more minutes.
3. When the security light stops flashing, you have FIVE minutes to start the next step. Turn the ignition cylinder to OFF and then back ON (RUN) position. The dash will flash for fifteen more minutes.
4. After the security light stops flashing the third time, the new key has been programmed into the vehicles computer and will operate the car. It has replaced ALL the previous electronic key codes and is the ONLY key programmed into the vehicles computer.
If you want to add a key....
1. Insert an existing key into the ignition cylinder.
2. Turn the ignition cylinder to ON (RUN) and back to OFF.
3. Remove the existing key and, within 15 seconds, insert the new key and turn it to ON (RUN).
4. The security light will light up for two seconds to indicate success in programming the key into the vehicle.
5. Don't attempt to start the vehicle with any key for at least 1 minute.
<HR>On-Board Programming Method "C"
for Ford keys (Later 1998-newer Ford, Lincoln, Mercury)
1. This requires that the vehicle be connected to special dealer equipment. There are two ten minute delays involved while this device erases all existing key programming and sets up the vehicle computer to accept new key codes. Two new keys should be ready because the system requires a minimum of two keys in the program. After the first two keys are programmed, additional keys can be entered individually by following the instructions for adding duplicate keys (below).
**You must have two original keys to perform this procedure. If you only have one key, you WILL have to take it to the dealer to get it programmed**
1. Insert and existing (working) key into the ignition cylinder.
2. Turn the ignition cylinder ON (RUN) and back to OFF. Ignition should stay on for at least ONE SECOND.
3. Remove the existing key and, within TEN seconds, insert a second working key and turn it to ON (RUN) and the back OFF. Ignition must be in ON for at least ONE second, but no more than TEN seconds. Remove the key.
4. Insert the new key before TWENTY seconds have elapsed and turn it to ON (RUN). Leave it the ON position for at least ONE second and turn back to OFF.
5. The security light will light up for THREE seconds to indicate that the new key has been successfully programmed.
6. To program additional keys, repeat steps 1 through 5
As a precautionary measure for all of the above procedures, you should wait at least one minute after you have performed this until you start your vehicle.
</SCRIPT>
Can start, but can't lock or unlock? Follow these instructions. It took me a while to figure this out.
Remember, the fob key has two functions. It is chipped to the engine to start the vehicle. Additionally, you have to program the remote lock/unlock functions in your new fob key.
Otherwise, if you simply marry a new key, using two original keys, this new fob key will only start the engine. Until you also program it as a remote locking/unlocking key, you won't be able to lock/unlock. So there are actually two programming steps- one for marrying the new fob key to your ignition, and one for activating the remote lock/unlock feature.
So, first , follow the instructions to marry the new fob key spare (third, fourth, etc) to your ignition system, using two original Ford keys. After programming the new fob key to start the engine, follow the instructions in this thread for activating the lock/unlock remote feature in your new key. Otherwise , you now have only a new, simple ignition key fob, and no working unlock/lock remote features.
If you're still having problems, locate a very good locksmith. They can program new fob keys,and maje vaket
Old Nov 22, 2016 | 06:08 PM
  #30
Auggiedoggy
F-150 ‘98-up
Ford Escort 99-up
Ford Focus ‘00-up
Ford Mustang ’96-up
Ford Ranger ’98-up
Ford Taurus ’96-up
Lincoln LS ’00-up
</SCRIPT>
If you're still having problems, locate a very good locksmith. They can program new fob keys,and make a spare valet key if you're needing a simple hide-a-key entry ignition key with a chip built in. A valet key does not replace your original fob key, just acts as a rudimentary backup in case you are locked out or needing to lend your car.
Bottom Line: Keep good spare fob keys for daily use , and put your two original fobs away. Losing either of these originals costs do ray me at the dealership $$$
